crx hybrid fuel injector question
New User
I have a b17 going into my crx, using a pr3 ecu and most of the original d16 harness. It doesn't have any fuel injectors on it, so what injectors do I need? are all B-series injectors the same? or are they different between vtec and non? or was there are year when honda changed from to saturated injectors? or is the only difference in the plastic connectors?
Re: crx hybrid fuel injector question (wignersfriend)
I believe that you can use any b series injectors. One thing to remember is that the older ones used a ballast, as honda said it made the injectors fire faster...umm.... whatever... i would use the 88-89 teg injectors for it. think that you would need the ballast too... not too sure though
What ECU are you going to use? If it is a pre-92 ecu you need to use pre-92 injectors. You can use a set of Accord LXi injectors. I had a b17 in my 92 cx and now its in our 89 dx with a t3/t4 turbo with 11psi.
