what kind of clutch to get?
I have a Y1 cable tranny what kind of clutch can i use? a 92-93 GSR one? 94-96 GSR? 99-00 SI? can i just use any B-series clutch? is there a difference between the clutches for a cable and a hydro tranny?
New User
Re: what kind of clutch to get? (DreamSpeed)
You can use 92-93 or 94-95 gsr clutch is does not matter. DO NOT use a 99-00 SI clutch from factory. They are junk and do not hold.
Honda1
http://www.evanshondaspecialist.com
Honda1
pressure plate from oem ITR (type R) are the cheapest and hold 15% more power then any other b-series pressure plate otherwise just get any other b-series vtec pressure plate (non-vtec will slip)
disc needs to be 90-3 integra gsr or ls gs (doesn;t really matter)style because y1 is 90-1 type tranny uses a different type of spindel then hydro trannies
flywheels from any b-series work well ITR is 15lbs any other is 18lbs....
ITR parts are the cheapest from dealer (pp is about $140-150 from a dealer and disc is about $90-100)
if you have a hard time search for mike K from naples acura best prices and he ship really quickly...
crx1856
06-05-2003 10:12 PM
