Injector help pleaze
Old Apr 1, 2001 | 10:30 PM
hopelessrex's Avatar
New User
Default Injector help pleaze
Ok please don't become upset because I have read every archive on injectors and still my question is not answered. Is it possible to use injectors out of a prelude in a b series motor. I see that 92-96 are peak and hold but 97 and up are saturated. So what would make it not possible to use injectors out of a 97 and up lude? Any info will be greatly appreciated.
Old Apr 3, 2001 | 12:46 AM
sgT's Avatar
sgT
Default Re: Injector help pleaze (hopelessrex)
injector plugs changed in 1996.
If you are using a computer that wants PH injectors, then use the 92-96 h22a injectors. If you are using a computer that wants saturated injectors,
then use 97+ h22a injectors.
Old Apr 3, 2001 | 10:18 AM
New User
Default Re: Injector help pleaze (sgT)
Thanks appreciate the info.
Old Jun 15, 2001 | 05:41 PM
Lyonel's Avatar
Would H22a injectors fit directly on to a JDM 1st gen. B16a? What's the difference between 'peak and hold' and 'saturated' injectors?
Old Jun 16, 2001 | 03:35 PM
sgT's Avatar
sgT
Default Re: Injector help pleaze (Lyonel)
yes, the 92-96 h22a injectors will plug right in.
peak hold injectors are low resistance and saturated are high resistance.
BlackCRX
Aug 22, 2007 04:23 PM
BlackCRX
Aug 22, 2007 04:22 PM
H22ACiViC
Mar 19, 2002 03:58 PM
DelsolVtec18
Oct 5, 2001 03:56 PM
Turbohatch
Oct 3, 2001 10:36 AM
