backfiring swap help
Old Jan 27, 2002 | 09:09 AM
OneSunkCivic's Avatar
Default backfiring swap help
I don't know what's up one day it's running fine but with a very low idle the next day I am backfiring and everything if the timing is fine then what else could be wrong any sensors??? Please Help!!!!!!!!
Old Jan 27, 2002 | 09:54 AM
Kataku2K3's Avatar
Default Re: backfiring swap help (OneSunkCivic)
Check ur MAP sensor, a stuck MAP can create a lean situation causing backfires. That's just one of the more simple things tho.
Old Jan 27, 2002 | 10:51 AM
Default Re: backfiring swap help (JDMspecEG6)
figured this part out. when I unplugged the map sensor it caused the car to run real rich I think which caused me to backfire I took the plugs out and they were blacker than black so I cleaned them up put them back in and now it runs fine but still have a low idle problem. Thanks
K20EF8Dx
Engine Management and Tuning
12
Aug 3, 2012 03:06 PM
adam00integra
Jan 2, 2012 10:03 PM
JDM-KIDD
Feb 5, 2011 01:04 PM
minititan
Jul 13, 2005 05:02 PM
