does vtec matter for force induction engines?
Old Jan 30, 2002 | 02:18 PM
Propulsion's Avatar
Default does vtec matter for force induction engines?
I am debating between a gsr or a Ls, I would probably supercharge either one, but just wondering if the difference will be that big. Because I heard that if you supercharge, vtec isnt that useful anymore, so why spend the extra $1500?
Old Jan 30, 2002 | 11:01 PM
HKxBlur's Avatar
Default Re: does vtec matter for force induction engines? (maxma01)
VTEC is best to the average guy with an average setup.. Most people are driving around for 1 to 2yrs without the s/c or turbo or whatever else is planned, and a gsr is good in this instance, since u won't need to get a gsr+ trans, i/h/e just to be competitive with a b16 or gsr..
Bottomline is that the both setups are equally good for any type of plans where mods do not only include bolt-ons and a supercharger.. If motor work is 100% in your plans and not 30%, then the blocks sorta equal out.. Then again, won't u be mad when you learn u can get custom vtec cams made to pull out more gains from an s/c..
[Modified by HKxBlur, 8:05 AM 1/31/2002]
Old Jan 30, 2002 | 11:28 PM
Kamin's Avatar
Default Re: does vtec matter for force induction engines? (HKxBlur)
if you supply enough fuel when vtec kicks in
it helps. ive asked the same questions.
Old Jan 31, 2002 | 10:02 AM
HaUTSaauce's Avatar
New User
go with the gsr i have had both
JDM B16A
17
Jul 24, 2006 09:47 AM
AIWFCIATR
Nov 19, 2004 02:34 AM
turbo89civicb18hatch
Jun 10, 2004 09:30 AM
Import RP
Apr 22, 2002 07:15 PM
