could someone explain what all i need for a LS/VTEC
lets just say i have a LS swap in my 94 hatch allready,,,,
what things will i need
also how reliable are they??
what are some pros and cons of this setup??
also,,what kinda qtr miles time might i see with this,,considering i have all the basic bolt ons????
is there a good trans to make this swap even batter
a car im lookin at has a LS swap in it,,with a GSR tranny,,would doing a LS VTEC on that b better then on a LS tranny???
the reason i ask is,,that if a LS/VTEC swap,,is gonna b faster,,and around the same price as a GSR swap,,i would rather do this then,,spend the same amount on a GSR swap
thanks for your input
mike
mike
Re: could someone explain what all i need for a LS/VTEC (Wrath of VTEC)
here is the answer to all ur probempoo poo UP IMPORTREVIEW!!!!!!!!!!!!!!!!
http://www.importreview.com/reviews/lsvtec.html
try that link to help u out
Re: could someone explain what all i need for a LS/VTEC (DragonCTR69)
Also it would be faster and Cheaper to just turbo your setup
dragon, u sum'd it up pretty good cept for the part at the end aobut the turbo
You sound like a real expert on the LS vtec but you went out the easy way and bought a Type R.
Good Job
Good Job
Re: could someone explain what all i need for a LS/VTEC (topspeed86)
dragon really is a stuborn old bastard!!!
anything can be reliable or unreliable. believe it or not there is only one way to do it right. the variables are what pistons cams and other power parts you use. those parts are what affect reliability, and we all know high compression kills, regardless if the block was a factory vtec. oh well, you guys do what you want. this has been beat to death and noone seems to want to be open minded.
