Auto to manual with motor swap???
93 hb,lx model, auto tranny, lsvtec, obd 1 swap, with cable trans. What is needed for this swap, I know I will need a clutch pedal assembly or at least the pedal. But will I need the hydro to cable conversion made by Hasport? I am also sure there will be a little wiring to do, i.e. 4 wires fro vtec, maybe an auto tranny sensor. Thanks for your help.
Re: Auto to manual with motor swap??? (hybridrex)
you'll actually need to move the tranny mount first since the 92+ auto civics tranny mount is in a different place from the 5 speed, then get the hydro to cable kit and run the lines. on the auto stuff, put the shifter in park, remove everything, and lock it there so the key will still come out of the switch. no wiring changes needed.
silencers91crx
10
02-26-2009 09:11 PM
moosepoop21
07-26-2006 07:05 PM
