Replacing clutch... which is easier... pull engine and trans out or just engine???
Banned
Re: Replacing clutch... which is easier... pull engine and trans out or just engine??? (therealcivic
pulling a motor isn't hard when u have the right tools. I have never done a clutch while the engine has been in the car. I don't know how hard it is. But I know it is very simple when it is out.
transmission is simple to drop.
pull axles out
remove tranny mounts, lower engine a few inches (so it drops on an angle) then unbolt transmission from block (just make sure you have a transmission stand or someone under the tranny if it falls.
its not hard to remove an engine tho.
eaiser to install the clutch with engine out of car.
pull axles out
CleanLikeJdm
02-11-2005 05:36 PM
ScottEK
16
09-26-2002 09:35 PM
