i know you you guys will tell me to use the search but....
what else will i need to buy to put a jdm 92-95 sirII (b16a2) into a 94 civic ex?
wiring harness?
motor mounts?
axles?
i tried searching for it but i cannot find anything on it
thanks
wiring harness?
motor mounts?
axles?
thanks
Former Moderator
Re: i know you you guys will tell me to use the search but.... (17secondcivic)
B16A2 is NOT JDM. The B16A2 is from the later 1997 Del Sol VTECs and the 99-00 Civic Si Coupes.
JDM motors will just say "B16A" on the block, with no 2, 3, or 6 on it like the USDM, CDM, and EDM motors will.
Are you SURE you're getting a JDM motor? What all does it come with?
Re: i know you you guys will tell me to use the search but.... (B18C5-EH2)
well im gonna order it from somewhere on here prob. jdmhondaparts.com. they say its jdm the one that has 170 horespower is the one i will order they say complete swap but i was just wondering if its as simple as just bolting it in or having to buy another harness and mounta and axles
thanks
thanks
Former Moderator
Re: i know you you guys will tell me to use the search but.... (tjtice)
You can use your Civic's engine harness and injectors for a harness.
From there if they don't give you all the stuff, plan on buying:
94-01 B-series axles from Integra (any), Del Sol VTEC, or Civic Si.
Exhaust manifold or header for 94-97 Del Sol VTEC or 99-00 Civic Si
94-01 shift linkage from Integra or 99-00 Civic Si - NOT Del Sol VTEC
Intake for a 99-00 Civic Si will fit fine, or 94-97 Del Sol VTEC
Throttle cable from 94-97 Del Sol VTEC or 99-00 Civic Si
I'm just giving you a few things, there may be other misc. stuff too depending on what you get from them.
GODD LUCK!
GODD LUCK!
jdmnic91
06-15-2015 07:11 PM
