injector resistor needed in this swap?
i'm doing a complete d16z6 swap into my 90 dx. i know if you're converting to mpfi you need an injector resistor box, but i'm using the '93 z6 ecu. do i still need an injector resistor box?
also, can i use the flywheel of off my old engine on the new one?
Re: injector resistor needed in this swap? (serious)
you need a resistor box for the low resistance injectors not the ECU...
dunno about flywheel...
HTH,
t..
HTH,
t..
SteveeeO
03-03-2003 07:38 PM
