H22 map sensor
Old May 26, 2002 | 11:06 AM
servion's Avatar
Default H22 map sensor
I'm putting JDM '95 h22 into a '97 civic cx. The chassis is converted to OBDI. The map sensor exists on the Trhottle body on the old motor, but my helms manual for the prelude tells me that the map sensor on the prelude is up on the firewall, so I don't have one. Do I need to get a prelude map sensor for this swap?
Old May 27, 2002 | 10:27 AM
servion's Avatar
Default Re: H22 map sensor (servion)
could I use my old map sensor and try to mount it somehow?
Old May 27, 2002 | 10:46 AM
Mikey3000's Avatar
yeah you can use the civic map sensor. as long as it's 5V it'll work. you don't have to worry about mounting it, it doesn't make a difference.
Old May 27, 2002 | 12:41 PM
servion's Avatar
Default Re: H22 map sensor (Boss Hogg)
holy crap.... (your sig)... what's your 1/4 time? That's pretty much exactly what I'm building towards.... nice setup.
Can you give me any help on the wiring? What all do I have to add? The cx was already wired for vtec (previously has a d16z6) and its OBDI. I can't seem to find anyone to help me with this topic. My other problem is vacuum lines. I have no idea where they should go.
Old Mar 19, 2003 | 02:21 PM
JdmCIVIC853's Avatar
So can you use a map sensor off of a h23 prelude on the jdm h22a
Old Mar 19, 2003 | 02:22 PM
poison's Avatar
Default Re: H22 map sensor (JdmCIVIC853)
Yes. You can. Most MAP sensors are universal.
Old Mar 19, 2003 | 04:38 PM
cccya's Avatar
Default Re: H22 map sensor (poison)
yeah use tour ols one, and don't buy a new one. i did buy a new one almost $300 from dealer.....man that sucked
mengo911
Feb 28, 2010 09:03 AM
squarepusher
Dec 18, 2006 06:24 PM
viet4gvtec
Sep 5, 2003 06:42 AM
JdmCIVIC853
Apr 16, 2003 09:27 AM
