Check SRS Sign
New User
Check SRS Sign
When my car got stolen some long time ago, my steering wheel was cut. The new one was put on but the SRS light on the dash never went away. Now, is there something that I can do in order to reset it or turn off the light (Not by unplugging the Blub )? Is it the ECU or is it some self managed SRS brain that is hidden? This is the case for a hybrid civic. Thanks!
Re: Check SRS Sign (Civikun1945)
you gotta jump the grey/grey 2 pin plug with a yellow harness that goes into your fuse box then turn the key to on. Then it will blink and turn off, disconnect the jumper until it turns back on and reconnect the jumper and it will turn off then disconnect it again. Somethin like that I had the same prob when i disabled em once Helm expalins it better if you got one
New User
Re: Check SRS Sign (MurphDog74)
Okie, thanks, let me try that. It sounds kinda complicating?!?!?! anyways, I guess I will try because it's a beautiful Memorial Weekend!! ahhh, gotta love summer!
dont do it unless your SURE how to do it
you dont want the airbags discharging.
at least go buy a chiltons before you do this.
if you can wait go order a helms. http://www.helminc.com
mikeyboost
03-26-2008 08:45 AM
777sC
07-16-2004 11:55 AM
