yet another 99 Ek HB swap question.
again,, i have:
mugen chipped p28 ECU
skunk2 OBDII to OBDI jumper harness
99 Si driverside and rear trans mount
the question: im getting a GSR engine, should i get the OBDI or OBDII version, becuase i do have that choice, both USDM, and depending on which engine is the one to go with, What engine wireing harness do i use? one of the GSR's? or go and buy a 99-00civic SI engine wireing harness?? ---this is for a 99 civic hatchback--
if someone can answer this, life would be great.
thanks
thanks
Re: yet another 99 Ek HB swap question. (JDM CRX)
get obdII
it will save you ALOT of headaches
and for the harness, what model civic do you have? (ex, lx etc) the easiest (and cheapest) way is to just use the stock harness and wire in vtec and butterflies .
good luck
good luck
