Anything I need to know before I install my shunk2 intake manifold ??
I just got a skunk2 intake manifold for my hybrid ( GSR B18C1 ). I know its a direct bolt-on but is there anything I need to know in regards to modifying anything (i.e.: throttle cable, any T-fittings, etc.....) ?? Thanks for the help.
Re: Anything I need to know before I install my shunk2 intake manifold ?? (KAMiN)
Im doing mine on thursday, Id highly recomend the hondata gasket while you have the IM off. I will post after mine is done. Oh yea, your going to need to extend your pcv hose so buy some.
[Modified by trustsi, 10:47 PM 5/26/2002]
Re: Anything I need to know before I install my shunk2 intake manifold ?? (Roger)
i have t-fittings if you need them(if you are OBD2). you will need a new t/b gasket. i am in your area so give me a PM if you need help.
1 Post
1. You WILL need a new throttle cable bracket. The gsr one is really really shaped weird. ITR or B16 should work fine.
2. You WILL need a new throttle body pully...anything non GSR.
3. You might need a new throttle cable. I know that the dx EK cables are really really long..not so sure how long yours is...you will find out when you do the swap
That should be it.
http://tiiite.b16a.com/tech/sk2manifold/
[Modified by geeyeeah!!, 9:23 PM 5/26/2002]
That should be it.
The Poopsmith
06-16-2003 07:24 AM
