Verify: JDM can be registered / pass smog in CA
Verify: can JDM be registered / pass smog in CA?
can some one please confirm that JDM motor swaps can or can not be registered and pass smog in California? i heard that they could, but also they can't. thanx
[Modified by trix are for kids, 2:15 AM 5/31/2002]
Re: Verify: can JDM be registered / pass smog in CA? (trix are for kids)
https://honda-tech.com/zerothread?id=170420
well friday was a good and a bad day....
the good news is(which was my biggest worry)....according to the smog ref they now allow JDM motors aslong as they have all smog equipment hooked up...and i passed emissions...
the bad news...i still failed...and i have no BAR sticker...
reasons for failing:
-threw code 1(heated O2 sensor) which is weird since i had no engine check light
-aftermarket FPR
-they wanted documentation stating that my ECU is for the motor
-Idle was at 900rpm instead of 700-800rpm
-and my timing was marginal at 18degrees
so i need get averything fixed and set up another appointment...i pray to the car gods for it to pass next time...
-aftermarket FPR
YellowCivic95
04-25-2002 12:01 PM
YellowCivic95
04-18-2002 06:13 PM
