95 ls in a EG having problems
Old May 31, 2002 | 12:09 PM
Nebula's Avatar
New User
Default 95 ls in a EG having problems
When I drove it today it was bogging alot and misfiring. My friend called me and he changed the spark plugs changed the motorharness checked all the lines everything. Do you think it could be the FUEL PUMP?? Guys please help. Any info would be great thanks
Old May 31, 2002 | 12:59 PM
Nebula's Avatar
New User
Default Re: 95 ls in a EG having problems (Nebula)
bump
Old May 31, 2002 | 08:09 PM
Nebula's Avatar
New User
ttt
Old Jun 1, 2002 | 04:10 PM
HybridHatchC1's Avatar
i had the same exact problem, are you sure you added the 2 wires for the O2 sensor right? thats was my problem and i had the same systoms, also check your distributer. i bet its somthing with the o2 tho
Old Jun 2, 2002 | 08:27 PM
LshatchTurbo's Avatar
New User
Default Re: 95 ls in a EG having problems (Civ-JDM)
What map sensor are you using. Remember you need to use the integra map sensor and not the civic one on a ls swap
EJ1_CRIS_909
Mar 2, 2011 02:01 PM
Rastaman
Jun 8, 2009 04:36 PM
globe
Feb 20, 2004 07:08 PM
