99 Ek HB swap questions.
werd. gots a 99 EK HB and i have a 98 USDM b18c1. i know the driverside mount and cast iron mount has to be changed, but will the trans and other mounts bolt in as well? or just go all 99 civic Si mounts becuase you cant go wrong? also, will the stock GSR axles and wireing harness work? or will i need the 99 SI axles and harness? thanks to al that help me.
Re: 99 Ek HB swap questions. (JDM CRX)
You need a 99 si driver side mount(under cam sprockets, bolted to motor), 99 si rear tranny mount, del sol vtec A/C bracket,
passanger front tranny mount and the rest are stock. You should have the harness that comes with the engine and your stock harness and match everything up. You will need to wire up vtec(no wires present), you need to rewire the iac sensor(a14-a12), I had to extend the tps and iat. Also the crank sensor needs something but I forgot. The axles will work. Also you need the shift linkage as the stock civic is puny, and wont bolt up.
Re: 99 Ek HB swap questions. (Trey)
doods,,,, 96-98 EK Hb's are different than 99-00's. i forgot the exact diffence, but i do know on that link that Trey has provided to me numerous times, it doesnt go through the 99-up swap. its something with the wireing harness now that i think about it, the plugs to the ECU are different. anyhow, thanks.
Homericaeast
05-07-2002 11:21 AM
