Jdm Map Sensor Question
Old May 27, 2002 | 12:30 PM
zerofighter777's Avatar
Default Jdm Map Sensor Question
I have 2nd gen jdm b16a engine that I swapped into a 95 civic and it throws a map sensor code. I was wondering what map sensor am I supposed to use. Is the small vaccum line on the throttle body where the map is supposed to be hookup? I checked the helms manual and shows for the usdm b16a map is on the throttle body. Thanks for your help in advanced.
Old May 27, 2002 | 01:43 PM
Kamin's Avatar
Default Re: Jdm Map Sensor Question (zerofighter777)
take the map off your old throttle body and just run a vacume line(from the old map) to the spot on the new throttle body. then like zip tie it to the firewall or somthing.
thats what i did
jphil101
Apr 2, 2010 11:36 AM
d15dreams
Oct 14, 2008 01:46 PM
SVOboy
Mar 26, 2006 11:48 AM
civichatch67
Sep 21, 2005 10:11 AM
zer0.
Jun 4, 2004 10:39 AM
