Did compression test.
Old Jun 1, 2002 | 04:15 PM
InfamousRS's Avatar
Default Did compression test.
It was right at 190 across all 4 cylinders. Number 2 was 189 and number 4 was 191. Does this seem about right for 10.1:1 compression?
Old Jun 1, 2002 | 05:29 PM
redteg1's Avatar
Default Re: Did compression test. (InfamousRS)
i have a gsr and i come up to 190, 210, 200, 200
Old Jun 1, 2002 | 06:15 PM
InfamousRS's Avatar
Default Re: Did compression test. (redteg1)
I have a b18b block with stock pistons, b16 head (milled .020). According to the copression calculator on http://www.c-speedracing.com, it should be about 10.02:1.
I re-used my 1 week old head gasket, could it be the head gasket for the reason its lower than yours?
Old Jun 1, 2002 | 07:02 PM
Kamin's Avatar
was the engine warm
was the throttle open fully?
Old Jun 1, 2002 | 07:13 PM
InfamousRS's Avatar
Default Re: Did compression test. (KAMiN)
The engine had run for about 10 minuts. Yes, the TB was open. Are you suppost to crank the engine till the needle stops moving up? Cause thats what we did.
krazeenoy
Jul 3, 2007 06:39 AM
BLK99VTECR
Dec 25, 2005 09:27 PM
tegasaurus
Dec 23, 2003 02:54 PM
eg crunkmonster
Mar 31, 2003 08:29 AM
