B16a or B18c
I have a 93 del sol si and want to put a different engine in it but im not sure what to buy. What is the difference between the two engines other than the hp. The b16a is $2350 and the b18c is $3300 and i guess i just wanted to know if the extra $1000 dollars would be worth it or not. Thanks
If your going to go through the effort and expence of a swap, go big.
I'm considering a similar swap for my 95 Civic coupe although I was looking at either a B18C or the JDM B18C5. It's a substantial price increase from one to the other yet the only differences I can see, other than the 20 hp gain, is a slightly higher compression, cam timing and lift, and a slightly higher final drive ratio in the tranny. I was wondering if a few simple mods to the B18C would achieve the same results and save a few bucks.
Plus, there's a temping offer on Ebay with seven B18C5 swaps (engine, tranny, mounts, axels, harness, ECU) for $4250 (+shipping)
BTW, for the topic--if you're thinking about a b16 vs. a b18c1, F a b16..they are weak
GSR all the way.
yup. gsr all the way man!!! I have saved up some money, and now I am selling my 95 gsr motor. I saved up for a b18c5 motor to drop into my hatch. I plan on running a t3/t4 turbo. Take a look at my other posts. I am selling my gsr motor (everything you will need) for about $3000. take a look.
But i love my gsr motor in my hatch, and I will love the itr motor even better.
go gsr!
go gsr!
reread my post. I said im looking for $3000 for my complete swap. its still in my civic now, runs fine. Everything will be taken out and sold. (mounts, tranny, P72 ecu, starter, 6 puck clutch, toda flywheel, 10.3 MM plug wires. The motor is very clean.
[Modified by 92hatchy, 9:27 PM 5/31/2002]
