b16a->b18c header ?...
Old May 31, 2002 | 11:07 AM
red96's Avatar
Default b16a->b18c header ?...
i've been searching, but can't find a definate answer to this question...
i know most parts on B series engines are interchangable, so will my DC 4-1 Ceramic B16a header fit the B18c i'm about to drop in?
thanks.
Old May 31, 2002 | 11:41 AM
Trey's Avatar
25 Year Member
Default Re: b16a->b18c header ?... (red96)
Yes.
The exhaust ports on the B series heads are the same.
The intake ports are the difference.
You'll be fine.
Old May 31, 2002 | 12:03 PM
SC0TT's Avatar
Default Re: b16a->b18c header ?... (Trey)
Wha? I thought the b16a header is too short for the b18c?
Old May 31, 2002 | 12:20 PM
red96's Avatar
Default Re: b16a->b18c header ?... (cr-tegra)
that's what i was unsure of...
Old May 31, 2002 | 01:32 PM
SC0TT's Avatar
Im almost positive a b16a header wont work on a b18c.
Old May 31, 2002 | 08:14 PM
Y2K Si FBP's Avatar
a b18 header will work on a b16...but not vice-versa...the b18 block is 7mm taller..so the b18 header on a b16 will hang lower (less ground clearance)
Old Jun 1, 2002 | 08:48 AM
91CivicSi's Avatar
I have a DC 4-1 header off a 99 Civic Si (B16) on my B18C1..no problems. On the other hand, a friend of mine couldn't use a Kamikaze B16 header on his B18C1.
Old Jun 1, 2002 | 09:54 AM
joeyitr309's Avatar
New User
Default Re: b16a->b18c header ?... (91CivicSi)
So will a stock b16a header fit a b18c? I am confused. I thought when you put a b18c into a 92-95 hatch your supposed to use a b16a header so it will bolt up to your exhaust with no modification. Please help
Old Jun 1, 2002 | 12:56 PM
Blue-Civic-Hybrid's Avatar
Loved
Default Re: b16a->b18c header ?... (joeyitr309)
That's what i have, works fine..
virginia_dude
Oct 17, 2004 05:00 AM
t0ekn3e
Apr 27, 2004 01:54 PM
1JDMDOMINICAN
Feb 10, 2004 01:13 PM
Aphrodavid
Jun 2, 2003 02:55 PM
eg6hatch
Mar 23, 2003 05:07 PM
