help water coming out on the tailpipe!!
i had a b18a setup on my crx and it was doing it also just because my headgasket was blown. Now that i have replaced my engine to a b18b, the tailpipe is still smoking. anyways here's my setup on my 89crx si --- 94ls w/ ctr high compression pistons(brand new), new headgasket and valve seals, and im using a 90ls computer, intake manifold and injectors basically a obd0 setup. I started it up last night and water was coming out the tailpipe. The plugs are pretty dry and there no leak anywhere, i dont have a check engine on my dash, i used a 91 octane gas and put a octane booster, i retarded the timing just a little bit, and a new o2 sensor but there was water coming out the tailpipe. What could be the culprit in this case? btw i grounded a wire from one of the radiator wire so that the radiator fan always comes on whenever turn the car on. your replies are very well appreciated.. thanks
Re: help water coming out on the tailpipe!! (sirb18a)
Condensation in the exhaust is normal. My car pees when I leave the garage
Now if it's enough to fill a small bucket you've got a problem...
its silly to always have ur radiator fan on. 1, it wastes alot of power because ur alternator has to put a heavier load on the engine to produce the electricy to turn the fan, and 2nd, ur engine does a good job of keeping itself at the right temp. The engineers designed the motor to run at around 180-220 degrees. They do this because metal expands/contracts at different temps. So let ur engine keep itself at the right temp.
As for the smoke, drive around and see if it goes away. It sounds like u just have water from it sitting.
jdmej814
14
03-11-2009 01:31 PM
TurBros
10
10-30-2008 03:59 PM
