o2 sensor question
Old Jun 2, 2002 | 12:51 PM
hondaeg5's Avatar
Default o2 sensor question
i have a 92 vx. is there any wiring changes i have to make when i swap in a ls motor. i know the vx had a five wire o2 sensor and the ls has a four. i keep getting fault code 1 and ive replaced the sensor with a known good one. just wondering before i go checking wires.
Old Jun 2, 2002 | 02:48 PM
Jared's Avatar
Default Re: o2 sensor question (hondaeg5)
Get a helms. the o2 sensor wiring is different between the two ecms. did you buy a brand new VX sensor? If so, how much did it cost you?
Old Jun 2, 2002 | 05:43 PM
hondaeg5's Avatar
Default Re: o2 sensor question (Jared)
no i bought the one for the ls(4 wire)
i have the one for the vx still though
[Modified by hondaeg5, 2:43 AM 6/3/2002]
Old Jun 2, 2002 | 06:14 PM
Jared's Avatar
I'm assuming the one for the LS didnt plug up, correct? isnt the vx a 5 wire unit? btw, how many miles are on that vx sensor?
Old Jun 3, 2002 | 06:45 PM
hondaeg5's Avatar
i think the harness from the shocktower to the ecu is different on the vx.
vx sesnor has 100000 miles.
[Modified by hondaeg5, 3:46 AM 6/4/2002]
Old Jun 3, 2002 | 07:52 PM
Jared's Avatar
But the LS O2 did plug up? Hmm, I'll have to do some digging on this one. What year is your VX?
Old Jun 7, 2002 | 06:12 AM
hondaeg5's Avatar
92 please help
Old Jun 8, 2002 | 11:17 AM
Jared's Avatar
But the LS O2 plugged up?
Old Jun 8, 2002 | 07:15 PM
hondaeg5's Avatar
yes. i used the engine harness for the integra.
Old Jun 8, 2002 | 07:17 PM
Jared's Avatar
ok, let me go see what i can find out about the harness differences.
Old Jun 9, 2002 | 04:17 PM
hondaeg5's Avatar
thanks for your help.
Old Jun 10, 2002 | 04:15 AM
9KRacer's Avatar
New User
I ran into the same problems when I swapped a B16 in my car. I am still having o2 problems..
Old Jun 10, 2002 | 11:45 AM
hondaeg5's Avatar
Default Re: o2 sensor question (9KRacer)
what code did you throw?
Old Jun 10, 2002 | 04:44 PM
hondaeg5's Avatar
ttt
Old Jun 11, 2002 | 11:15 AM
hondaeg5's Avatar
up
Old Jun 12, 2002 | 03:08 AM
hondaeg5's Avatar
ttt
Old Jun 17, 2002 | 04:29 PM
hondaeg5's Avatar
im guessing nobody with a vx ever ran into this problem?
[Modified by hondaeg5, 1:30 AM 6/18/2002]
Old Jun 18, 2002 | 06:42 PM
netnutshatch's Avatar
I find that very hard to believe.
Old Jun 19, 2002 | 12:48 AM
B18C4-T's Avatar
Default Re: o2 sensor question (netnutshatch)
I amhaving the same problem in my 92 vx. I can't remember if I always had it or if it was only after my Hondata 2b, I posted about wiring an a/f guage in though.
Old Jun 20, 2002 | 08:50 AM
hondaeg5's Avatar
Default Re: o2 sensor question (B18C4-T)
does it throw code 1?
Old Jun 21, 2002 | 04:03 PM
hondaeg5's Avatar
up again
Old Jun 24, 2002 | 03:49 PM
hondaeg5's Avatar
up
craig88crx
May 19, 2008 03:04 PM
Aespooncivic
Jun 8, 2005 04:40 AM
TriK
Jul 2, 2003 10:56 AM
H23vtecEG
May 18, 2003 05:36 AM
SpoonFedHatch
13
Mar 16, 2003 08:18 PM
