Checking codes in a hybrid
Old May 28, 2002 | 11:22 PM
raene's Avatar
Default Checking codes in a hybrid
This is a real hybrid. P28 ECU (OBD1) in a CRX Si (OBD0) hooked up to an OBD2 engine (D16Y8). Can anyone tell me how to jumper the pins to check the ECU codes?
Old May 29, 2002 | 03:51 AM
lelopez's Avatar
Default Re: Checking codes in a hybrid (raene)
Just jumper the pins that you usually jumper to check your timing......it is a two pin plug either on the driver's side on the engine bay (88-89 models) or on the passanger side inside the car near the glove box (90-91 models)
let me know if you're still not clear
Lester
lelopez@eng.usf.edu
Old May 29, 2002 | 11:08 AM
raene's Avatar
Yellow two-pin plug covered with a rubber boot, sitting between the shock tower and the coolant reservoir?
Thanks
Old May 29, 2002 | 11:12 AM
lelopez's Avatar
that's the one.......
Lester
crx si B series
May 26, 2015 05:00 PM
chriscool888
Jan 3, 2012 01:27 AM
UndergroundTuning
Jan 20, 2009 07:36 PM
CeeJayy
Jul 27, 2007 07:48 PM
SCsol
Oct 7, 2005 05:35 AM
