Benefits of this swap
Old Sep 6, 2016 | 08:46 PM
Hondalyfe95's Avatar
Default Benefits of this swap
What would be the benefit of swapping out my d16z6 for a b20b in my 93 civic coupe aren't they around the same go? I wanna do this swap but is it worth it or should i go for a larger engine if I want more hp
Old Sep 6, 2016 | 08:47 PM
Default Re: Benefits of this swap
Help plz
Old Sep 6, 2016 | 09:00 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The B20B will make significantly more torque... and the HP will be nominally improved unless you get the high compression version. The swap weighs about 135 pounds more than a D-series engine/trans package, so you have to remember that some of your new found HP will be used to tote the extra heft.
Worth it... only you can decide. Larger and more powerful engines make the decision much easier with respect to the gains being more dramatic compared to the D16Z6... but they will be a more expensive solution.
Old Sep 7, 2016 | 02:51 PM
I'm definitely going to go turbo that's For sure I'm trying to get At least 220hp what turbo kit would you prefer I'm thinking about a greddy turbo kit. Would i be able to get those numbers with a b20b and a gsr trans i probably have to go low compression right ?
Old Sep 7, 2016 | 02:53 PM
What engine are you running with that supercharged h/b I bet that's real fun to drive
Old Sep 12, 2016 | 01:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The supercharged hatchback is a "B" series... the H22 civic is a straight "H", no H to B conversion.
allanthios
Jan 24, 2008 10:50 AM
1988project
Jul 28, 2005 07:49 PM
joop411
Aug 23, 2004 07:54 PM
24valvage
Mar 30, 2003 05:25 PM
Spade
Oct 16, 2001 06:14 AM
