95 integra B18C1 SWAP
Hello, trying to help. A buddy out, we swapped in a B18C1 (OBD2) engine into his 95 integra. It won't start unless we dump gas into the intake and after it uses up the gas it will die. Gets fuel to rail, has spark, I'm thinking the fuel injectors aren't getting power.
It has an LS ECU, checked for check engine codes and it throws code 4, CPS, but if I'm not mistaken it bypasses the CPS since its OBD1 right? Any help would be awesome. Thank you
chokinvicts
01-10-2004 07:17 AM
