JDM d15b vtec turbo build
Alright guys I've searched every friggen thread on here, d series, homemade turbo, and a few others and I can't find 100%
of what I'm looking for. Okay so to start it off my end goal with my build is 300hp, a reliable daily, and boosted of course. I plan to get stronger Pistons, rods, head studs, and probably leave the cam stock cause it's already got an aggressive cam. I know that the JDM d15b vtec shares the same rods as the d16z6 but it's got shorter Pistons for the shorter stroke. So I came across this piston and rod kit for a USDM d15b which has shorter rods than stock and I believe the same sized Pistons as the d16z6 so I think it should work out. As I mentioned it doing a turbo build so I want a compression ratio between 8:1 and 9:1. I'll post a picture of the details for this kit I saw. My two concerns with it are 1 will they sit flush with the deck. And 2 if they fit, will the rods fit properly on the crank? Are all d series crankshafts the same size? Thanks guys I'm hoping to get some straight forward answers with this and finally start getting some parts together.
montanacivic
12-29-2018 04:16 AM
kevinweinmann
09-26-2016 06:33 PM
