Prelude s2000 swap
Old Dec 17, 2016 | 03:43 PM
PreludeS2000's Avatar
Default Prelude s2000 swap
Hi i am swapping a f20c rwd into a prelude 5.gen, the engine that i have has been converted to be used with kpro, and sins i am using another standalone i need the wiring for s2000 cam and crank senors. I have looked for the s2000 2006-2009 workshop manual and donīt seem to find it. Is there a possibility that you guys could have it?
Old Dec 18, 2016 | 06:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Prelude s2000 swap
The KPro conversion basically transforms a '00-05 "F" series engine into the '06-09 F22C engine sensor signals... so if you use an engine management system for a '06-09 S2K and a DBW throttle body, you will be good. Otherwise, change the crankshaft and exhaust cam wheels and sensors back to '00-05 "F" series parts and run engine management for the '00-05 application.
Old Dec 19, 2016 | 07:41 AM
I am going to run the engine on a vems standalone, i am wiring it up so i only need the pin out for the cam and crank sensors on the 06-09. f20c
deeh22bubble
Honda S2000
Oct 19, 2011 12:38 PM
Ian.G
Honda S2000
Feb 17, 2011 09:39 AM
IIBPIIprelude
Honda S2000
Feb 7, 2004 08:52 AM
5150CRX
Honda S2000
Apr 9, 2003 11:43 AM
