B16a into em1 code 7 and code 15
Old Oct 30, 2016 | 11:30 AM
Bagged_em1's Avatar
Default B16a into em1 code 7 and code 15
I am swapping a b16a into an em1 using a p30. I have stock b16a2 injectors, b16a2 alternator, b16a dizzy with jumper harness, p30 ecu with jumper harness,I before had a problem with a crank no start, distributor was put in incorrect. Now it will start and idle fine, but when reved it stalls and when you left off the gas it goes back to idle. 2 codes code 7 and code 15. One is tps and the other is something ignition related. Any help? Car will idle but won't rev unless you baby the throttle then it only Revs to like 2k sounds like the car is in limp mode to me. Any help would be appreciated as this is my first swap
Old Oct 31, 2016 | 06:09 PM
DVDr's Avatar
Default Re: B16a into em1 code 7 and code 15
It sounds like distributor is still wired wrong.
code 7 : TPS
code 15: Code 15 Ignition output signal
Is the distributor rotor on correctly and not worn, is the distributor cap new. all your wires installed correctly, plugs descent.
Those are items i would check after checking the dizze wiring.
hondab16a
Mar 20, 2008 12:35 PM
mugenbattle
Dec 13, 2003 06:12 PM
TheHatchHog
16
May 15, 2003 11:26 AM
CRexDX
Apr 10, 2002 06:37 AM
