B16y8 or swap
B16y8 or swap
Need some help deciding to either to upgrade my d16y8 to get as much hp as i can or if ita better to swap for a different engine since it does have alot of miles buget of around 3500 (just for swap) if it matters
If anyone knows what would be better the help would be appreciated
Re: B16y8 or swap
What other motors fit without really any changes? Or what i would need in order to make it fit in place? And i know its not the best but its also automatic
Re: B16y8 or swap
dang if its an auto your going to need a few things check out this thread for the auto to manual conversion, https://honda-tech.com/forums/honda-...4pics-1337459/ that is just for the conversion ....new mounts, ecu, center console, clutch pedal, cluster...its going to be some work. once you do the conversion you can literally put whatever you want in unless you want a k or j series then you need a new subframe and shifter adapter
ProjektHB
15
09-10-2003 04:12 PM
Smith Wise
03-26-2003 05:21 PM
