OBD-0 Dizzy to OBD-1 harness wiring diagram needed. Searched
I need a wiring diagram to convert an LS OBD-0 dizzy to a LS OBD-1 wiring harness. Thanks. I searched but it pulled up so many thatit's taking a really long time to sort through so I was hoping that someone would know where it is off hand. Thanks, kinda in a hurry thats why I'm doing it this way.
* B A N N E D *
Re: OBD-0 Dizzy to OBD-1 harness wiring diagram needed. Searched (TwoKSiR)
All The wires are the same color from the obd 0 to the obd 1 except on the obd 1 there is a yellow and green wire that needs to be connected to the bigger white wire on the obd0 dist. (the white wire that is alone on the clip). But if u are running a obd 1 ecu the obd0 dis will not work becouse the timing will be off. If you look at the coil from the obd1 dist. u will see the tip that comes out is off to the lest where as the obd 0 dist is in the center.
Re: OBD-0 Dizzy to OBD-1 harness wiring diagram needed. Searched (ESP.net)
dont know if you know this or not... you cant use an OBD0 dizzy with an OBD1 ecu... it wont fire the injectors!
TwoKSiR
10-30-2007 12:47 PM
TwoKSiR
10-30-2007 12:40 PM
