00 b20z in 91 si hatch falls flat on face when punched
ok here is the parts list
00 b20z
91 si harness
ls intake mani
0bd0 dizzy
0bd0 pr4 ecu
91 si injectors
new ngk spark plugs
new sparkplug wires
new cap and rotor
ok so the car runs perfect at idle and drives fine as long as you barley touch the gas and dont pass 2500 rpms but once you stomp on it or pass 2500rpms it sounds like a rev limiter and doesnt move at all everything is hooked up no check engine light untill i try to punch it a code 12 (egr) shows up untill the car is turned off the motor doesnt even have and egr ?????????
also would an auto ecu have any effect on the drivability thanks
and yes i have searched and searched
00 b20z
91 si harness
ls intake mani
0bd0 dizzy
0bd0 pr4 ecu
91 si injectors
new ngk spark plugs
new sparkplug wires
new cap and rotor
Re: 00 b20z in 91 si hatch falls flat on face when punched (boosted96midorihatch)
what about your fuel pump..? it's possible you aren't getting enough fuel supply at higher rpm or engine load.
i've also heard of clogged cat. conv. having similar symptoms.. so it may not hurt to have that checked out.
hope you figure it out soon, that sounds like a fun setup.
Re: 00 b20z in 91 si hatch falls flat on face when punched (hondamark35)
fuel pump seems to work fine but thats probly our next fix and there is no cat just a 4 ft pipe after headers
Hollywoood
Audio / Security / Video
01-29-2005 08:06 AM
