what ecu's are you H2B guys running?
i have a 98 gsr so im not sure if i should chip the p72 or if i should go with a p28. What are you guys running?
Re: what ecu's are you H2B guys running? (401tuner)
You can really do either one. If you want to use the IAB system then just keep the P72, but if your going with an S mani, or something like that then use the P28. P28 won't look for IAB or knock so...
Either will work for what you want.
Re: what ecu's are you H2B guys running? (2fast4u831)
i was planning on getting a ecu from phearable.net but i wasent sure witch one i should have them put a basemap on for me. And what size injectors (ill be using stock h22a injectors) and where i should set the 2 step n rev limit?
Re: what ecu's are you H2B guys running? (2point2)
ok but which one do you guys suggest getting a basemap put on for an h22 from phearable.net .. the car will be tuned later on after the cams and such go in.
It doesn't need a "basemap" per say...it just needs a basic stock H22 set of maps. From there if you want to have it tuned on site you can, but if your keeping stock injectors and for the mostpart, a stock motor, it'll run fine on stock maps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401tuner »</TD></TR><TR><TD CLASS="quote">haha im sorry "guys and girls" .. by the way you have a very nice set up so i give you props </TD></TR></TABLE>
flattery will get you everywhere,
p28 with a chipped h22 basemap, for now. Not sure what I'll be doing afterwards, probably Crome
SolAssassin
Engine Management and Tuning
02-04-2009 02:33 PM
