LS/vtec Troubles!!!!
Old Dec 3, 2007 | 09:07 PM
b18muoio's Avatar
Default LS/vtec Troubles!!!!
I got a b18b bottom end wit b16a head.....the motor is freshly put together ran motor to drive on and off trailer, then parked in garage until tuned. So i decided to check fluids and radiator was low so i checked oil and found some coolent in the oil and lil sittin in the head??????? Any ideas other then maybe having the wrong head gasket ?? PLEASE HELP
Old Dec 4, 2007 | 06:15 PM
sirtef9's Avatar
Default Re: LS/vtec Troubles!!!! (b18muoio)
is it leaking anywhere else? whats the mileage on the head and the block? boost?
Old Dec 6, 2007 | 07:19 AM
lucky4586's Avatar
Default Re: LS/vtec Troubles!!!! (sirtef9)
head gasket ... the golden eagle ls/vtec kit is the only setup i would use to do a ls/vtec!! I have seen too many ls/vtec die because they didnt do a good job tapping it and what not.
Old Dec 6, 2007 | 07:25 AM
2fastGSR's Avatar
King of the One Liners
Default Re: LS/vtec Troubles!!!! (lucky4586)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucky4586 &raquo;</TD></TR><TR><TD CLASS="quote">head gasket ... the golden eagle ls/vtec kit is the only setup i would use to do a ls/vtec!! I have seen too many ls/vtec die because they didnt do a good job tapping it and what not.</TD></TR></TABLE>
x2
Old Dec 7, 2007 | 10:26 PM
DC209's Avatar
i really hope you used the golden eagle kit
Old Dec 8, 2007 | 04:50 PM
killerpenguin21's Avatar
Default Re: LS/vtec Troubles!!!! (DC209)
the golden eagle tap yes, but the headgasket is junk.
88.REX
Nov 17, 2009 08:46 AM
da9lsvtec91
Dec 9, 2008 05:07 PM
string
Aug 21, 2006 07:46 AM
Linton
Apr 1, 2004 02:24 PM
tysir
Aug 20, 2001 07:27 PM
