JDM B20b - won't start - what am i missing?
I just pulled the b18a1 - It is a 1990 Acura Integra w/ OBD1 coversion harness.
Got spark, got fuel, compression good, thermostat ground valve cover ground, and tranny ground all hooked up.
OBD1 LS Injectors - B20 basemap in a p72 w-hondata (doing a B16 head by spring)
Only things changed since I pulled the LS are injectors (was using DSM450's with resistor box (I removed the box and spliced all 5 wires together)
And the ECU (was using a LS chipped ecu)
And changed over to an H22 throttle body w/ map sensor. (removed the EVAP canister and the old map and purge solenoids)
What the hell am I missing?
Its cold and late!
Its cold and late!
Mr. Badwrench
Re: JDM B20b - won't start - what am i missing? (Honda_Fanatic)
you need 4 things for the enfgine to run
1 fuel
2 spark
3 compression
4 correct ignition timing
if you have those 4 you need to start looking at the map.
1 fuel
2 spark
3 compression
