k20 heads
Old Dec 5, 2007 | 03:55 PM
allmotorh22's Avatar
Default k20 heads
Can somebody explain to me about the k20a3 heads and k20z head and how they work and are they ok to use if your gonna boost you car.
Old Dec 6, 2007 | 06:22 AM
lucky4586's Avatar
Default Re: k20 heads (allmotorh22)
Yes they work well for boosting and what do you really want to know about how they work?
Old Dec 6, 2007 | 10:56 AM
H.Veras's Avatar
The K20A3 heads are the ones that came in the Civic EP3, which only uses V-tech on the intake cam, and nothing on the exhaust cam. The K20Z heads on the other hand came with V-tech on both the intake and the exhaust cam. K20A3 heads flow better at low rpm because they were designed to provide low end torque, while the K20Z flow much more better at high rpm.They both make good power, but the K20Z is a much better head then a K20A3.
Old Dec 12, 2007 | 01:33 AM
civic.slow's Avatar
* B A N N E D *
Default Re: (H.Veras)
k20z3 and k20a2 castings are the exact same. the k20a3 has a weaker vtc, smaller ports, and i belive i-vtec only on the intake.
go to k20a.org.............................as anybody who makes a comment on here. 2/3rds of them have NEVER seen a k series piston....................or a single part for that matter...............they just look at pics on the internet.
Old Dec 13, 2007 | 09:02 AM
high_revs's Avatar
Default Re: (civic.slow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic.slow &raquo;</TD></TR><TR><TD CLASS="quote">go to k20a.org.............................as anybody who makes a comment on here. 2/3rds of them have NEVER seen a k series piston....................or a single part for that matter...............they just look at pics on the internet.
umm you dont to see parts hand in hand to know what you are talking about...there is plenty of info on h-t about any k series head.
Old Dec 24, 2007 | 11:06 AM
Player_One's Avatar
K20A3 heads suck.
K20A/K20A2/K20Z1/K20Z3/K24A2 heads good.
The K20Z3 and K24A2 are slightly different though as they have the extra EGR stuff and slightly different intake manifold casting and can take the RBC intake manifold without modifying the IM.
They're all okay to use if you're boosting. However, you don't want to boost as high if you've got a higher compression ratio. Anyway, there's a YouTube vid showing a K20A2 blowing at 42psi. http://www.youtube.com/watch?v=iOcqMOSvpRI
happyabortion
10
Dec 2, 2018 10:02 AM
GABOCRX
12
Apr 1, 2014 03:09 PM
squeezedeghatch
Mar 6, 2009 04:57 PM
TGUNNER
May 2, 2002 07:38 AM
