JDM & USDM h22a tune up parts the same?
might sound like a stupid question but ill be ordering a jdm h22a to start my h2b project for next season. And im wondering if i can just buy a OEM timing belt and water pump from honda. Or if i need to buy specific parts seieng it is a JDM engine and not USDM?
Modified by 401tuner at 4:53 PM 11/18/2007
Re: JDM & USDM h22a tune up parts the same? (401tuner)
i purchased my jdm h22 from hmotors. i replaced the timing belt, switched to a manual tensioner, and replaced my water pump all with OEM parts from hondaautomotiveparts.com
Re: JDM & USDM h22a tune up parts the same? (hpi247)
okay great thats all i needed to know. I just wanted to make sure that the parts were interchangeable. Anyone else have any opinions?
King of the One Liners
Re: JDM & USDM h22a tune up parts the same? (JayWest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayWest »</TD></TR><TR><TD CLASS="quote">same timing belt and water pump </TD></TR></TABLE>
Called up my pops ( works at a dealership) and had him order timing belt and water pump for a 94 prelude ( have a jdm h22a ) and yes they work fine
is that enough yes answers for you ?
Re: JDM & USDM h22a tune up parts the same? (2fastGSR)
only difference i actually found between usdm and a jdm h22 is the thermostat. had to make a couple trips finding the right size. i believe a 96 usdm thermostat sis the correct one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayWest »</TD></TR><TR><TD CLASS="quote">same timing belt and water pump </TD></TR></TABLE>I've switched my jdm water pump and timing belt out with usdm from hondaautomotiveparts.com. Works fine as everyone else has stated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hpi247 »</TD></TR><TR><TD CLASS="quote">only difference i actually found between usdm and a jdm h22 is the thermostat. had to make a couple trips finding the right size. i believe a 96 usdm thermostat sis the correct one.</TD></TR></TABLE>
very true.
I found that out the hard way as well
very true.
