2point6's CB7 going K24
Just wanted to let those who are interested know that I dropped my Accord off at Hasport today, so they could fab up the engine mounts, axles, and wiring harness needed to make the K24 swap possible. This kit will be based on the CRV or Accord K24 mated to an Accord gearbox.
The kit is due to be released at the end of December '07 or January '08.
Stay tuned for updates as I will post them as I get them.
He knows where you live!
Re: (Tyte-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyte-S »</TD></TR><TR><TD CLASS="quote">$$$? and for what years are these mounts going to be offeed for?</TD></TR></TABLE>
What do you mean?
It'd probably be the same price as the CD ones at $700 and would cover all the CB chassis
What do you mean?
Re: (raceACCORDingly)
Unfortunately, the 94-97 Accord K-Series kit is significantly different and won't work in the 90-93 Accord chassis.. It makes more sense when you have it all in front of you..
I'll see if I can't get a few spy shots of the work in progress..
Re: 2point6's CB7 going K24 (-RedneckDave-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point6 »</TD></TR><TR><TD CLASS="quote">This kit will be based on the CRV or Accord K24 mated to an Accord gearbox. </TD></TR></TABLE>
K-series gearbox correct?
Re: 2point6's CB7 going K24 (AFAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AFAccord »</TD></TR><TR><TD CLASS="quote">
I'm guessing one of those two motors mated to the K24 Accord gearbox (or at least i hope
Re: 2point6's CB7 going K24 (TheMuffinMan)
They're the only ones that fit. RSX, TSX, or Accord.
Re: (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash »</TD></TR><TR><TD CLASS="quote">Unfortunately, the 94-97 Accord K-Series kit is significantly different and won't work in the 90-93 Accord chassis.. It makes more sense when you have it all in front of you..
I'll see if I can't get a few spy shots of the work in progress..</TD></TR></TABLE>
spy shots would be sweet.
when we dropped an f22b1 in my buddy's cb7, all i can think of that was diff is, 90-91 accords had different tranny mounts while 92-97 were the same. rear and side look a bit diff but bolted right up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -RedneckDave- »</TD></TR><TR><TD CLASS="quote">Damn Scott I am gonna miss seeing the H22 updates.</TD></TR></TABLE>
The H22 is still alive in my drag Civic. I will continue to work with the H platform, but I need to shift gears a bit and that is why I am putting the K series in the Accord.
</TD></TR></TABLE>Yes, sorry if I wasn't clear enough.
Re: (pos_cd5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 »</TD></TR><TR><TD CLASS="quote">i guess 2point6 wont have the fastest NA H22 accord no more... </TD></TR></TABLE>
I believe that someone else holds that record anyway...
Either way, the Accord will continue to go faster.
Re: (locash)
yea putting the 94-97 motor in the 90-93 accord requires modifications and different motor mounts....so making a fab kit try and fit would be hard and would likely not work and you would just waste time and money
Re: 2point6's CB7 going K24 (rochesterricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer »</TD></TR><TR><TD CLASS="quote">I expect at least a couple people to call you a traitor </TD></TR></TABLE>
LOL... don't worry the H22 progress is still continuing as well.
