a question???
i have a 93 si hatch (usdm) and a 96 b18b1 (jdm) and the upper drivers side mount does not line up right
does anyone have a info for me? ohh also i had a b18b1 (usdm) in there before this engine so i figured that it would would be an drop in job
Thank You,
Justin
Thank You,
Justin
Well, regardless if you are mixing up some codes, there are 2 types of drivers side mounts for the Bseries.....there are 2 bolt or 3 bolts styles (how mount bolts/nuts required to bolt the mount to the side bracket).
Get the proper combination of both (or buy the right ones if you don't have the proper combination with everything you have already, which you should) and put it together.
We do offer mounts that work, but still need to know what you have.
Maybe you should put up a picture of what you are working with and what is not lining up for you.
TurboLaxx
19
Feb 20, 2006 11:37 PM
