ecu questions for h22 in 95 civic dx
i already know i can choose from either the p13, or a chipped p28. so far i am planning on going with an h22 long block from hmotors. however, i wont have the map sensor, or the iab. is there a link that someone can point me to off the top of their head that covers the iab? i know that you can disable it with the p28, but what is it for? would starting with the p13 be best to get it on the road? i have access to a tuner who is well versed with hondata and neptune.. would going that route be a better bet?
here is my current proposed built sheet
h22 motor with ecu from hmotors $1,400.00
h2b kit from evolution industries (on ebay) $1,249.00
94-00 teg axles from advance auto $140.00
94-00 integra int. shaft
92-95 prelude engine wire harness
inj. Resistor box ebay $25.00
new water pump from adavnce auto $63.00
new water pump gasket from advance auto $6.00
new timing belt from advance auto $34.00
balance tensioner eliminator kit $125.00
lower d series alt. on h22 $115.00
belt for alt. Schucks Dayco 5030295
saprk plugs ngk platnum $12.00
spark plug wires $46.00
oil filter $3.00
synthetic oil
b series trans on ebay $200.00
gearspeed trans rebuild $2,300.00
fluidyne radiator ebay $284.00
fal fan ebay $178.00
header with mod megan racing $195.00
teg linkage on ebay $24.00
clutch and p.p kit ebay $147.00
the junk yards here suck for integra parts.. i about **** myself when i saw 2 95 teg's sitting side by side. all that was left was the rear trailing arms from one which will be going on my ride in the next few days after the bushings get replaced.
i plan on asking HT when i get closer to buying everything if people have things for sale like the linkage and int. shaft. etc. plus seaching the FS thread for things like the radiator or fan and clutch cheaper.. etc..
any thoughts would be most helpful. support is support, even if its online support.
oil filter $3.00
synthetic oil
Re: ecu questions for h22 in 95 civic dx (A1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A1 »</TD></TR><TR><TD CLASS="quote">why no map and iab sensor?</TD></TR></TABLE>
i called hmotors and when you order the long block, they do not come with the long block.
JDM_4_LIFE
30
01-03-2004 10:55 AM
