custom wiring h22 into cx hatch.
Hi all.
Im not really sure if im in the right spot but ill give it a go.
I have a jdm h22a engine currently in my 92 hatchback and need to fabricate a wiring harness since i cut mine into itty bity peices.., the goal was to run every wire from each sensor to the ecu and connect it on the firewall with CPC connectors.. anyway i think im going to can that idea and basicly run every single wire from the engine to the ecu un cut then have a cpc connector inside the car to connect it to various sensors
"tach/vss/ground/voltage/ecu/cel light to dash" backup voltage exct..
also eliminate non neccessary things also..
anyone done this before? im trying to find some documentation on obd1 pinouts and persay what all needs to be connected at the bare minimum to start the engine minus any cel's that will occur while its running.
i have both the 93 lude and 92 hatch bookoo service manuals and am looking at the electrical sections of both to compare/notes for color's on wires and such..
if your a knowlagable person please reply or hit me up on aim likwidchz..
thanks a bunch.
--aaron
thanks a bunch.
--aaron
turboex
06-15-2003 08:40 AM
cccya
04-07-2002 07:56 PM
