DC integra k swap?
DC integra k swap?
im considering a k24 swap in my 99 gsr, i searched a bit and didnt find what im looking for, i would like to catch up with someone that has done this already and could tell me some things. I need to know what axles to use since i have jdm itr hubs that need 36mm splines, are rsx axles the right length and spline? also any other info would be so helpful, ive done swaps before, but mostly d and b series in dc and egs so it was real simple, this one seems a little more involved and i will take all the advice i can get. thanks -Josh
Re: (suicide_shift)
yes rsx S axles will bolt right up with hasport axles. contact me if you need someone mechanicly inclined to perform the swap for you in case you arent doing it yourself. located in NY also.
Re: (chameleon)
i am going to do the swap myself, but i may need a hand with technical stuff, i plan on running the stock k24 for a season while i gather the rest of the parts to do a built hybrid with the k20 head, the thing that is worrying me is the wiring, i suck at that, i did my jdm hid front end and wiring the lights is about as deep as i wanna go with wiring, i know i need a radiator out of an rsx and i need the type s trans, if you guys can think of anything like small parts i need that wouldnt think of at first, it would all be helpful.
igorka_91
01-06-2014 07:16 PM
youngwon22
10-14-2003 07:47 PM
