Obd2 engine in obd1 Car
Old Apr 10, 2018 | 09:09 AM
DogmaTacics's Avatar
Default Obd2 engine in obd1 Car
This has probably been covered over and over , but I recently replaced a blown motor I got off a homie for a steal.
i had a motor already ready to drop; a D15B (Two Vtech Solenoids 😉 ) that's obd2
The motors already dropped in and running into a 98 Civic that’s obd1.
the only issue I ran Into was my tachometer and speedometer not reading but the rest of my cluster reads just fine
I was digging around and kinda figured that my issue is going to be with the Obd issues because my speed sensor worked fine prior.
my only question will a Obd2 to obd1jumper harness will rid me of my problem .
The Vtech On my D15B is engaging and the motor is running as it should it’s just that tach and speedo issue I ran Into
any help or insight is greatly appreciated
Old Apr 10, 2018 | 06:34 PM
muellersfan's Avatar
Default Re: Obd2 engine in obd1 Car
Make sure the tach wire in the distributor runs directly to the cluster.
Check for code 17 for the speedometer problem.
JusAccord
Nov 2, 2011 03:53 PM
emooheo
Mar 13, 2010 12:37 PM
frstbte14
May 31, 2007 01:22 PM
1man
Jul 21, 2003 11:45 AM
Kid1320
Jan 18, 2003 05:21 AM
