J swap no spark
Old 12-20-2017, 12:58 PM
Default J swap no spark
need 94 integra to 99 odyssey wiring
not getting spark but has fuel
immobilizer chip desoldered
i have pulled ecu and key ignition with key and harness from donor van
im a bit confused on driver tower shock wiring
i need help
ecu is in and all connections to A plug seems to be correct
DroolinMoron is offline
Old 12-20-2017, 03:18 PM
Default Re: J swap no spark
ANyone??....
Old 12-30-2017, 11:29 AM
fracas's Avatar
Did you pin the shock tower plugs right on the passengerside kick panel area?
fracas is offline
Old 01-02-2018, 05:40 AM
I hope I did, I followed my schematics on both integra Haynes and the engine I swapped in a odyssey 99
currently I only get fuel in.
And sometimes when when I turn key off to pull out it backfires really loud??
Old 01-03-2018, 11:24 AM
Well I decided to buy a AEM box
my own p8f was fried, hence no spark.
Hope to get this thing running.
Old 01-13-2018, 05:10 AM
fracas's Avatar
Arm v2? Those will work just fine for you. But now I believe you have to pin the ecu plugs (on the harness) to work with the aem.
fracas is offline
Old 01-13-2018, 03:46 PM
Hey, so a little update, I bought a 1060 aem v1 box, I read online someone ran a j32 in a sand rail so I decided to go for it. I just lost the page and I donít know how they did it. And yes I repinned it all and it is all correct on my laptop, just no sparkAnyways, everything is good, but still no spark? Am I missing something, Iím checking the jumpers in the aem box and itís factory.Itís all set to 1-2 on the jpt1-jpt2(crank and cam)But since my engine(j35a1) has no distributor and needs to run off crank and cam, should it be on the 2-3?? I did notice two thingsStart stat sync is offCoil#1 is off.Iím assuming thatís why no spark but whatí should I check...
Old 01-18-2018, 04:07 AM
fracas's Avatar
From my understanding the v2 is the one u want for the j swap in a civic. Have u tried contacting Don from RPM Motorsports? He is a j guru and get u started right up over the phone.
fracas is offline
Old 01-20-2018, 06:48 AM
I got this version box because I saw it at a cheaper price and thought I can repinnit to work but recently I only see 5 coil outputs so it gots me worried lol... and I saw someone didit on a sand rail online somewhere, may have to resell and save up for the v2...
I actually emailed him once awhile back I forgot why, I think I was about to order a harness from him, but then recently I figured it out. I may have to give him a call, I havenít had a chance to try my new settings and calibration yet on my box I been sick and in ER, seems like the flu is hitting everyone hard...On a side note, is does the j35 Fire two cylinders at once or one during the firing order? 1-4-2-5-3-6? Like does 6-1 fire together then 4-2 etc... sorry if that sounds dumb...
Old 02-02-2018, 02:36 AM
fracas's Avatar
I' not 100% sure on the j35. I have. A 03 j32a2 cls6 swap.
fracas is offline
Old 02-05-2018, 12:50 PM
Old 02-05-2018, 12:53 PM
oops didnít mean to quote, I havenít had time to mess with it yet, I will keep updating just Incase someone decides to try something confusing as I am doing, lol.
If all else fails , v2 aem it is :/
Old 02-07-2018, 02:18 PM
Freedo_Civegra's Avatar
Are you talking about Tim Beadle?
I'm pretty sure your J35 only fires one cylinder at a time.
Freedo_Civegra is offline
Old 03-07-2018, 04:54 AM
yes I think so,
another update, I called aem they told me I needed a type of trigger kit to get spark with what I was trying to do, or convert my j35a to a distributor. I didnít want to buy another kit and add more confusion.
my solution: resold my v1 1060 box, bit the bullet and bought the aem v2. Fires right up, now Iím just finishing vinyl wrapping my car and off on the road I go!!, thanks for the replies I hope whoever tries what I tried doesnít. Lol
Old 03-07-2018, 06:26 AM
yes I think so,
Good deal! Glad to know someone else has a J-swap. I love mine! TORQUE.
Old 03-17-2018, 07:27 PM
Probably last update:
incase someone is doing a j35a1 swap with the 6051 aem box and canít get it to idle correctly.
i had to add a little bit of fuel, and had my timing at 10degrees btdc.
I struggled wondering for 2 hours why it wouldnít stay on lmao.
I skipped timing sync step, and checking fuel tables.
Derp. Thank you everyone for replying, hope this helps another j35a1 swapper out.
Old 05-12-2019, 06:00 AM
Default Tuning question
I didnít want to make another thread on this so I decided to post here.
following up on my success getting my car started, everything is great, been a year and a few months, Iíve decided to start tuning more for power or at least a tad bit more efficient on high end, I plan on turboing it but Iíd like to know a few things that Iím concerned about. I want to tune what I have now until I gather my turbo together.
1. I have my BTDC at 10 fixed to lock in my timing with the program, but in my ignition tables theyíre set high around 19-25 low load then upper on WOT itís down to 8.7, Iím assuming the higher the number the more advanced timing it is... so at WOT itís set 8,7 across? Shouldnít it be more advanced to 12-16? Or son like that? What is ideal for this?
2. Is the BTDC 10 degrees for a j35a/j32a?
3. My AFRs are 12.8-13.7 at WOT at the moment which is Where I want it for NA, but when VTEC engages it goes to 16? Iíve tried adding more fuel but it seems excessive to jump lean like that or is that normal? Iíve only done 1-2 pulls ever.
I mainly cruise but now I want to go fast lol
my mods are
j35a1 with j35a4 intake manifold
Intake
full 2.75Ē exhaust dual out
And a manga flow catalytic converter lol.
1990CRXSIJDMEF8
04-11-2010 05:22 PM
9secg23eg
11-28-2009 10:19 PM
red civic standard
07-18-2002 03:13 AM
Quick Reply: J swap no spark
  • Ask a Question
Question Title:
Description:
