Accord V6 6MT ---> EG Civic J swap?
Hello all. I own a 2004 accord v6 6mt, with about 130k miles on it. I was looking into how much it would cost and take to repair and restore my car, and it seems it may be well over 1000$. I had always thought about eventually doing a full swap of my engine and transmission into a lighter, more nimble frame like a civic, and I'm considering going in that direction, instead of dumping more into the accord. I know there is a lot of info out there, but most posts deal with people having to scavenge all the required parts. I suppose I am in a good situation to do this, since I have the car itself and all the parts needed; as fa as I know, I just need an EG shell. I wanted to consult this forum and see from those with experience before I move on with this. I do a lot of work myself, but a full engine/transmission swap sounds quite intimidating. So, my questions are as follows:
-Roughly what will it cost?
-What will I need? (assuming I have my accord and an eg shell)
-How long will it take?
-Is this extremely difficult? (I'm mainly concerned about having the required tools, I don't mind hard work)
Thank you all for any replies.
(Also, is there any way to change my username? It was supposed to be "According.to.Plan")
Re: Accord V6 6MT ---> EG Civic J swap?
You really don' want to use the accord motor. But you will want to use the tranny, starter, shift cables, shift box . The ideal motor is a j32a2, j35a4, j35a8. The all have more power and there are more supporting mods out there to buy for the swap to work. I'm using a true 6sp manual swap out of a 03 acura cl-s. .You can also go that route if you like. Just takes a while to find that year car for the true 6sp set up. Just remember if you buy any of those motors that you make sure to also get the engine harness, ecu, key, and immobilizer..
So you'd be transplanting everything from your car into a civic? The EK has more room than the EG, I think.
You'll need a swap mount kit and custom axles for this, and you'll need to swap sides with the civic radiator.
Both Hasport and Innovative make these mount kits. I prefer and highly recommend Hasport, but they're a bit more $ than Innovative. Hasport kits offer different height options so that you can choose between oil pan clearance and hood clearance. I used the EKJ1 mounts and have a gaping hole in my hood.
For axles, Hasport, Insaneshafts, and Driveshaftshop make them. You'll need to be sure to tell them you're using an accord intermediate shaft as it's different from the Acuras. I used Insaneshafts, but all three of these companies have excellent customer support. DSS is $$$, though. Hasport could be a one-stop-shop for both mounts and axles.
You'll need an upgraded fuel pump (WALBRO!!!) and a fuel pressure regulator Aeromotive and Fuelab make some good ones.
It took me 3 days to get the wiring done. It was killer, but I think it was worth it.
v4lu3s
03-28-2012 06:20 PM
