B20b4 distributor with em1 obd2b harness
Just put a b20b4 into a em1, using em1 harness and distributor has a different style connector. Upon searching i can find lots of typical obd2a to obd2b. But not much on this crv style plug.
Anyone know where i can get a diagram for this crv dizzy plug for re pinning a em1 connector? Or where i can get a conversion harness.
Top one is the crv dizzy connector, bottom is the typical obd2b off harness.
Re: B20b4 distributor with em1 obd2b harness
I need wiring color details if you wouldn't mind? I need to wire the crv 10 pin (8 wires) to small rectangle plug. (8 wires). I can't find anything about which wire is what on the engine harness side. I have it running but still getting code 9 cyp so I think something is in wrong spot.
mycrx7
02-23-2008 03:01 PM
MoogieBoogie
08-05-2005 06:30 PM
