Swaped b18b1 into ek does not start
Old 08-29-2018, 03:06 PM
Default Swaped b18b1 into ek does not start
I have a 96 ek civic I bought a running Acura from a friend of mine it ran perfect before I started to take it apart anyways it sat around for about 1 month while I got parts for the swap and the engine once it came time to swap my engine I did everything correct I think I used the civic wiring harness and the Acura ECU everything plugged in fine I had a mechanic check it where I work he said everything seemed fine but now it does not start the timing belt is good and TDC is right we did a compression test and they all came out to have 0 compression the engine seems to have spark and also fuel going into it what could it be that itís not starting
LittleT147 is offline
Old 08-31-2018, 09:07 AM
Default Re: Swaped b18b1 into ek does not start
typo?
Feriohhh is offline
Old 09-01-2018, 05:20 PM
Originally Posted by Feriohhh View Post
typo?
my bad all the cylinders came out to have no compression
Old 09-01-2018, 09:50 PM
With zero compression in all four cylinders... you are either out of mechanical time, you have a really tight valve adjustment or the engine is crap.
JRCivic1 is offline
Old 09-02-2018, 10:01 AM
This.
Feriohhh is offline
  • Ask a Question
Question Title:
Description:
