H2B H22A w/F22 crank main seal oil leak
Old 01-14-2018, 09:12 PM
Default H2B H22A w/F22 crank main seal oil leak
Hello all!
Anyone here using a F22 crank (95mm) on an H22 block?
As above says, I have an JDM H22A block with an F22 95mm stroke crankshaft and con rods. The problem I am having is that (apparently) the main seal is leaking a lot of oil. When I say a lot, is just way too much.
I haven't confirm is the main seal (didn't had time to), but don't think there is other place that can leak on that side.
I pulled the out because​​ of this and decided to do the H2B. I put a new oil seal, but started the motor just to see that it is leaking. Engine was running for just a few minutes, and the leak was too much.
Does anyone have similar setup?
To tell a bit more, I bought the car already with the H22 and the F22 95mm crank, balance shaft eliminated with Ktuned kit, and manual tensioner.
​​​​​On the pictures it havd the flywheel spacer.
gmcuajo1 is offline
Old 01-15-2018, 11:32 PM
Default Re: H2B H22A w/F22 crank main seal oil leak
Can you take a picture without the flywheel spacer/adapter on the crankshaft end please ???
JRCivic1 is offline
Old 01-17-2018, 05:34 PM
Unfortunately I am not where the car is right now, and it is in tbe car with the transmission. On the pictures you can see the edge of the spacer. What I think can be happening is that I pushed the seal too far in.
gmcuajo1 is offline
slagman
03-31-2017 11:02 AM
wtsapexipowerfc
11
05-28-2011 04:47 AM
red civic standard
07-16-2008 07:55 AM
ham
02-22-2006 07:53 AM
Quick Reply: H2B H22A w/F22 crank main seal oil leak
  • Ask a Question
Question Title:
Description:
