1991 civic dx d15b2 block y8 head questions
Old 04-02-2019, 09:54 PM
TorMenT's Avatar
Default 1991 civic dx d15b2 block y8 head questions
1991 civic obd0 dpfi mpfi conversion already done. jumper from obd0 to 1 with a p28 ecu. i put a y8 head on my d15b2 block but i cant get this pile to run.. it cranks , has fuel, compression is good, has spark. i just learned the dizzy on a y8 does not have crank position sensor in it like the d15B2 does. i think my engine wont start due to this , im not familiar with any of this. so my questions are
1. could this be whats holdin me back?
2. Can the engine run without the crankshaft position sensor?
3. If I use the Y8 distributor what do I do about the missing crankshaft position sensor ?
4. can I use the d15b2 distributor on the y8 head?
TorMenT is offline
Old 04-03-2019, 04:51 AM
AllMtrRex's Avatar
Default Re: 1991 civic dx d15b2 block y8 head questions
Not sure about the OBD0 d15b2 distrubutor but all D15 OBD1 distributors will work on Y8 except d16z6 and d15z1
AllMtrRex is offline
  • Ask a Question
Question Title:
Description:
