B18b in 2000 civic ex no start
Old 02-28-2018, 03:22 PM
jspinelli8's Avatar
Default B18b in 2000 civic ex no start
I have a 99 b18b in my 2000 civic ex. Tried to start it up for the first time and it cranks when i turn the key but wont start. Im almost positive that its not getting fuel but i dont know why. All fuses are good but it could be a relay. Im not sure what relays to check. Also a few sensors are not hooked up yet including the one on the factory airbox piping, ckf sensor and o2 sensor. Also there is no ground coming off of the starter should there be a ground from starter to chassis?
Old 02-28-2018, 07:14 PM
jspinelli8's Avatar
Default Re: B18b in 2000 civic ex no start
Could it be the main relay? Its not gettjng fuel and i still have to check for spark
Old 03-02-2018, 07:04 AM
I like the tuna here
DumpdEJ6's Avatar
When you turn the key to the second position, do you hear the fuel pump prime for a few seconds?
Old 03-02-2018, 10:16 AM
jspinelli8's Avatar
no i hear nothing & i checked the wires for power they’re not getting any
Old 03-02-2018, 02:10 PM
jspinelli8's Avatar
Any ideas?
Old 03-02-2018, 06:29 PM
MastaFlyMason's Avatar
Thermostat housing ground
Old 03-02-2018, 06:51 PM
jspinelli8's Avatar
when i first cranked it there was no thermostat housing ground but now there is. When i have key in position II all pins coming from main relay get power except 5 and 7. But all of the fuses are okay so what could be the problem?
Old 03-05-2018, 09:30 PM
Randolph's Avatar
No ground from starter, lol.
Ground from Valve Cover to radiator support.
Ground from transmission to the chassis.
What ecu you have plugged in? Main relay? Fuses good? Thermostat ground (already mentioned)? Double check over everything. Make sure when you turn the key forward once then twice you hear the fuel pump kick on. If not, that could be your issue right there.
Funkwheat
63
02-24-2016 10:43 AM
CaseyB
11-16-2012 06:03 AM
oh-yeahcrx
10
11-27-2010 07:16 AM
InTheLBC20
11-25-2008 02:44 PM
matmcg
02-17-2008 03:34 PM
Quick Reply: B18b in 2000 civic ex no start
